safedepth
More advice sought please.
During testing yesterday I found 80 volts on the cpc of a socket ring with respect to earth and neutral.
TT installation. Ze, tested using multimeter was 92 ohms.
Ring continuity was correct,
r1r2 was correct,
IR was clear at 299M.
All items were unplugged, 3 items on fused spurs, all disconnected.
All sockets removed from walls, no indication of any problem.
RCD on circuit, 30mA tested correct.
The only thing we could find that gave any hint was all cables from this board, ( a 15 year old single RCD board fitted as part of an extension), were bunched together passing through the wall from old to new building.
All tested with a Megger 1552.
Could 80 volts be generated by self induction?
Any ideas.
Incidentally, I rang the NIC tech help line who couldn't. (Help that is)!
r1r2 was correct,
Any ideas.
