Sub main design without measuring Ze (EDITED TITLE)
NozSpark
Seaman stains™
May 28, 2008
12,338
147
North Wales Riviera
If you've read my post about the worshop leaky roof then you'll know that I have very tight constraints with turning the power off... basically I can't except for planned work and this is causing me a little bit of difficulty..
Right enough flannel,,,
It's a TNS supply and I'm going to replace the existing sub-main with SWA via a 60A BS1361 metal clad switch fuse... so how do I go about calculationg the Zs?? in my mind I'll have to use the guidance Ze of 0.8ohms..
now this is now causing me a little problem in that the guidance Ze is already above the max Zs of the fuse (which is 0.7ohms), so I guess I'll have to design RCD protection into this sub-main,,
My current thought is that I'll have to put a 80A 100mA 'S' type RCD in the switch fuse instead of the main switch,, what do you recon??
Use BS88's not 1361's for a starter mate.
Have you a Ze at the moment?
Have you a Zs for the origin?
Don't go as low as a 100mA unless you have to.
Work on your existing Zs at the origin then work your Zs out @ the termination.
Remember in ind/comm you often have lots of steel around!
You can use structural steel as your earth rod in a TT remember.
Use the <50V rule unless you need the rcd for additional.
This way you could get away with a 500 even?
Try to do some discrimination calcs on your downstream cpd's.
Off up the hill now night all.
Use BS88's not 1361's for a starter mate.Book in van I'm afraid,,, nearly put BS88Have you a Ze at the moment?No Ze at the moment and it'll be difficult to arrange for power off (except for the job)
Have you a Zs for the origin?That was something I was thinking about
Don't go as low as a 100mA unless you have to.Fairy snuff, prob go to 300mA 'S' type then
Remember in ind/comm you often have lots of steel around!No extraneous steel work in this building,, brick/block construction
You can use structural steel as your earth rod in a TT remember.Yep,, I've done this in the past
Mine red
Cheers.. I'll have a better look at it tomorrow
what do you recon??
I reckon, as you are an elder member, you know you should put a more descriptive title to your thread in order to help a great deal with SEO.
I thank You!
There you go Admin,,,
just like you asked;)
anyway, what's all this elder member stuff???? are you saying I'm old??? ;)
---------- Post Auto-Merged at 13:46 ---------- Previous post was made at 13:30 ----------
Who hoo,,
Just been back there this morning and measured the Zs at origin, PEFC and PSC
Definately TNS
Zs = 0.12 ohms
PEFC = 0.94kA
PFC = 2.3kA
so it seems that I will get away without having to RCD the submain...
Final circuits will have RCO protection though;)
Using 17m x 16mm 3c SWA fed from a 63A BS88 metal clad switch fuse my calculated readings are
volt drop = 2.38v
Zs at sub DB = 0.166 ohms (with 1.2 correction factor)
Oh,, and I don't know why I put it as a BS1361 before because I have got a price for a BS88
