Hi hope someone can help. Some years ago I run a supply to my shed (two sockets and two lights) and all is still in place and operating as usual. My issue is that I may not have installed it up to scratch according to regs and I want to clarify.
The sheds supply is spurred from the house ring main (RCD protected at the DB) via a sfcu, the spur goes through the wall to an outside socket, it continues down steel conduit into an adaptable box (under patio) where it connects (via crimps) to an SWA that runs the length of the garden (buried) to the shed. In the shed the SWA is terminated to a DP sfcu where the load side goes to an adaptable box (it is accessible) to feed BOTH the socket and light circuits wired in 2.5 and 1.5 respectively.
In hidsight I could/should I have put in a second fcu (next to the last socket) to supply/protect the lights and account for cable size reduction; however the supply is already protected by the sfcu where the SWA comes in at 13a, so is this necessary ?
The joint under the patio is inaccessible but if its filled with resin thats alright isnt it ?
BTW ive got C&G 2360 pt's 1 & 2, never did the NVQ 3 thou and tbh dont think I ever will.
