Surge Protective Devices
binky
retired and loving it!
May 7, 2008
15,153
2,058
Sunny Plymouth
2 questions, prompted by the tick boxes on EICRs:-
1/You don't see many SPDs, as in the mains incoming type to protect say a house, but I was thinking how would you test a device is working? From what I've seen of the small single phase units, there is no way of testing a device.
2/ I've looked at SPDs a few times, and all the bumpf waffles on about lighting stirkes. What I can't work out is whether an SPD would protect a house from something like a pole transformer fail, or just the general voltage spikes you can get off the mains supply?
Learning Lounge has a video on how it responds to various voltages and spikes, but then we just like the explosions :D
As far as I know, they are self testing.
As they have a limited life, i.e. number of operations, then testing them would be self defeating.
Once the fault indicator comes on it's time to replace them.
They are a glorified VDR/MOV across the supply & ground, so they shunt fast rising transient voltages to earth.
Thus, they will protect against other transients.
As far as for examle a slowly rising voltage caused by a failing Tx N, causing the supply to skew I don't know, not my area, I don't work with the supply side really.
You need to look at the manufacturer’s data.
A 500V DC IR test won’t affect a 250V SPD when it is rated at 25000 amps. Threshold 250V*√2=354V.
They should be disconnected for IR tests as they will give a false reading.
so in short we can't really test a SPD is really working?
No different to not being able to test a fuse or circuit breaker though, and RCD testing is only really of limited value IMO.
You could by having a variable voltage supply with a current sensor. The MOV/GDT should start to conduct once over its threshold value. In a way, a bit like ramp testing a RCD.
A 1000V Megger should in theory show a dead short.  :pray
