Sw Fused Spurs
r.b
Feb 8, 2011
379
Normally aw fused spurs when I put them in are to one side of the washer space, freezer space etc at my house and the layout of it I can't get the washer spur outside of the washer space next to it.My. Question is can the washer spur go in the washer space?.The only other thing is have the washer spur on another wall and have the single socket going straight down the washer space.I know you don't have to have the freezer,washer spurs setup but I chose it sure I've seen spurs directly above the spaces on site anyway
Cant really understand your post mate.
Are you talking about putting the fused spur above worksurface controlling socket hidden behind appliance. So if it caught fire you could isolate from above worktop by using sfcu?
Id just put the sockets in cupboards next to the appliance. Majority of my customers dont want sfcu's all over their backsplash looking sh1te.
Not sure if thats any help but couldnt really understand your post
Cheers
It all depends on whether your washer has a hot or cold feed. If it has a hot feed then maybe, if it only has a cold feed then perhaps it may. Make sure you don't get the two mixed up or the machine wont rinse properly.
Dont forget you cant mix up the hot and cold feeds, Cold water will not flow through a red hose (hot feed) and vica versa this is due to the hoses being impregnated with an aquaphobic dye which stops the two being mixed up.
ah so that's why all my white washes end up pink. ill fix that right away.
It embarrassing when its an underwear wash :(
Any how , we need more information to give a definitive answer, is the washer
A) On the left or right side of the kitchen
B) Is it white or silver (or other colour)
C) Are there windows that open in the room
D)  Is there more than one exit door
Once we have these replies  the aquabatic equation can be calculated to check the CSA of the PDA meets the relevant BS level
And does the machine have double overhead underhangs ?
