smith.james0
- Mar 21, 2014
- 7
- 0
I am looking at the size of swa cable I would need to feed my garage, at sometime in the past someone has used 1.5mm twin and earth hung between the house and garage
I am looking to feed the garage directly from the cu in the house to a cu in the garage. The garage is about 18 meters away (the garage is only 1.5 meters from the house but the cu is the on the other side of the house), the cable would be run above ground attached to the house wall then, attached to a wall to bridge the gap between the house and garage. In the garage there are 3 double sockets, 3 x 6' tubes, supply to the decking lighting and an outside socket.
Can anyone advise?
James
Can anyone advise?
James
