are you telling me to just use 6mm swa 90 deg and put it on a 32 CB?because that would make it cheaper and easier to do.
i think ill ring him tomoz and ask for some detailed specsexactly for what he plans to put in there.
Well obviously going overspec it will be electrically safe..
But personally if ain't needed why put in bigger stuff..
As my fist point 50A is nearly a whole house supply load for many a property around the country!
and if this is just ONE 23" X 11" room 50A just seems way over the top to me?
based on that assumption... most houses would need 250A+ of supply power!!
I may be wrong but from what you have said..
I can't see where all this extra power requirement is coming from?
IMO.. I would guess many kitchen/utility rooms in the average domestic home are using more power than your garage will be using? ?:| :|
Just take a step back in time..
when I were a lad..
the electric had 4 circuits...
30A ring
30A cooker
15A imm heat
5 amp light..
Our home had no Gas heating..
(the night time storage heaters were mostly cold by the time I got back from school) :_|
and we had electric fires & fan heaters etc.. plugged in during some real winters when we had SNOW!!!
The whole house.. was on 30A ring & 5A lights...
& a 60amp main fuse most likely... cuz that was the rating of the main switch on the 4-way wylex box!
I would most certainly agree it is best to check on a realistic assessment of what actual appliances are likely to be used!
