- Feb 10, 2009
- 342
- 18
I'm installing an inline timer fan connected to bathroom lighting so will be using 3 pole isolator in loft next to fan for isolation.
Client wants to be able to turn fan off at night.
Obviously the permanent Line (connected to fan L1) is usually powering the fan during overrun.
Currently all accessories in house are chrome flatplate.
Can I use a matching 2 gang switch (external to bathroom) - one switch for lighting and one to switch what would normally be the permanent Line to the fan to achieve this or will the lighting Switch Line (connected to fan LT) still trigger the fan to run without a feed to fan L1?
Hope thats clear!
I guess what I'm asking is does the fan always use the feed connected to L1 to run even when not overrunning? or does is swap between the feeds to L1 and LT?
Hope thats clear!
