fit the isolator yourself?I don't have the juristiction to make that call. I'm given a box and told to fit it.
You have several options. For example;Maybe an obvious question, what happens if you go to do a CU change and the undersized tails are between the meter and CU? you cant open the meter abnd change them. Henleys? Curious because I am doing a CU change tomorrow and havent really done one for a long time (been in heavy industry most of my career).
Ive never had any probs with MEA ,You have several options. For example;ii) Break the seal on the meter/ fuse and replace the tails (when I lived in North Wales I always did this and MANWEB never complained although other suppliers - like mine here on the Isle of Man do not take kindly to their seals being broken)
. :^O
Option V seems like a good one although in my experience the job will still be waiting for me!You have several options. For example;i) Use the existing undersized meter tails and make a comment on the DEIC that you fill in at the end of the job. That way you have covered yourself. Obviously great care would need to be taken as you would be working live.
iii) Cut the tails between meter and CU and fit an intermediate switch in an enclosure--- or alternatively a L&N henley block as you suggested. Obviously great care would need to be taken as you would be working live.
iv) Phone MANWEB and request that they fit their own intermediate switch. This would be the safest and most practical solution because you could then avoid working live and breaking any seals.
v) Phone the boss and tell him you're not feeling well and go home sick, then someone else will have to do it. :^O
cus its tight fisted not too!!! and you have probably got it in your price.why upgrade when 16 are fine and then just put a 2 colours sticker on the board
Contact supply company as they will usually agree to you cutting the seals and fitting new tails then they get them resealed my the meter man (yeah right).Option V seems like a good one although in my experience the job will still be waiting for me! Didnt consider opening the meter and changing the tails. I wont be working live, no isolator means fuse will be coming out. No probs with pulling fuse not sure about opening meter seals to change tails tho... we'll see what I'm faced with tomorrow. This is the first CU I've done under 17th.
What happened to:Ive never had any probs with MEA , but if working in Pully or somewhere similar I always resealed anyway,
but not much call for private work there anyway.
sorry,?What happened to: I never remove the fuse, sealed or not,
just put Not Verified on the cert.
you are not allowed to remove the DNO fuse, that my friend is where you contravene reg 16 of EAW,
unless you are an employee of DNO that is.
BTW,What happened to: I never remove the fuse, sealed or not,
