Good evening all, I've just done a CU change in my own home. Everything went well until i realise i wouldnt be able to terminate my 16mm main earth into the side of the supply cable's bullet fuse which currently has a 6mm earth in it. The holes on the earth block are too small to get 16's in. Any suggestions on how to over come this. please let me know. I had to leave the current 6mm terminated but linked to my 16mm main earth and 10mm bonding via the main earth block i installed. All replies will be appreciated, thanks.
