Since Canoeboy`s excellent question has piqued interest, I thought I`d add another, maybe slightly easier one.....
Here`s the scenario:
You`ve installed a ring final into a room which is to be used as a practical classroom. The specification has called for emergency stop buttons to be fitted to the circuit.
You can either post a diagram or drawing; or describe how you`d wire such a circuit.
Be aware of the following stipulation: The circuit must NOT re-energise on release of the emergency stop. A separate "reset" switch must be used.
Please provide diagrammatic or descriptive schematic, and list the materials needed to complete the project.
1. You need to provide 4 no. emergency stop buttons.
2. The wiring is to be installed in 20mm PVC conduit - the same conduit the ring final wiring is installed within.
3. The ring final feeds six double socket outlets; is wired in 6491X 2.5mm throughout. Ring length & tests are not part of the exercise.
4. The OCPD is a B32 BSEN60898.
5. The distance from the DB to the final emergency stop is 16 metres.
6. The reset switch must be key-operated.
Good luck
KME
Good luck
KME
