Traineeboy
- Apr 22, 2020
- 201
- 17
If I wanted to obtain the Zs for a ring final circuit that had a spur ( furthest point ) Then from what I under I would take the Ze and add the R1 + R2 readings. Ze is 0.15 and R1 + R2 is 0.15 so the measured Zs would be 0.30.
However I was told that I could obtain the Zs I wouldn’t have to do the above I would just need to plug my Megger tester in at the furthest socket (in this case it’s a spur so know it’s furthest point ) Put in on Loop Z and L-PE and Select 2 lead Low setting. I did that and got 1.39.
Those readings a very different it’s convenient fused me as I thought it was Zs = Ze + (R1 + R2) but then I saw the thing about plugging in the tester while the install is live and it tells you the Zs but as I said the readings are very different.
please help me understand this
* its confused me - not convenient fused lol
