Just having one of headbang these moments.
Just starting a rewire where the meter tails are past their best. Meter was replaced last year. So, being a rule abiding electrician, I rang up YEDL to find the supplier of the property to get the fuse pulled. British Gas.
Rang them up - here's a brief description of conversation -
Me: I need a main service fuse removing to carry out essential work.
BG: What's that. Is it the white box that switches off all the rooms in the house?
Me: No, that would be the consumer unit. I need the main fuse removing so I can change the consumer unit.
BG: Well, you can do that can't you?
Me: No, as you are the supplier to this property it is your responsibility.
BG: I've never heard of this before but i'll go and check.
Me: (irritation level risingheadbang)
BG: (having returned) Is it the box with the switches on?
Me: No, that's the consumer unit which I am responsible for. YOU are responsible for the meter and the main fuse.
BG: How long do you need it taking out for?
Me: About 20 minutes.
BG: I'll go and check again.
Me: (irritation level contuining to riseheadbangheadbang)
BG: (having returned...again!) Yes, we can send somebody round. It'll cost
