Whilst on holiday in Canada my brother found some work for me to do in his house (typical). I did some research and found an old and now banned 2 way switching method known as the Carter method that was commonly used there & the US.
Note they call the live or phase 'Hot' & show the connected cables as red & non-connected as black. They also call 2 way switching 3 way.
How dangerous, depending on which end is switched you are breaking the live or the neutral & reversing the polarity across the lamp. Only ES lamps are used so the outer exposed connection could be live. No wonder its banned. I found this method disconnected in my brothers car port.
Another interesting 2 way switching circuit is called the California method which seems a good idea. You always have a live, neutral & switch line at all points in the circuit. This would need 4 cores plus an earth but you could add a light anywhere on the circuit.
Their regs are all 2 (3) way switching has to have all cores inc the neutral carried in the same cable. Different electrical licenses & regs apply to domestic, industrial etc.
