The Long Run..
what about a seperate fuse board in kitchen area with a main 6mm t+e and 10mm earth back to main head to dist board in kitchen ??
Now you're spoiling me...
:p
yellow77 (magic slippy stuff!)
3x2.5 t&e in 20mm, (only one big long sweeper of a bend tho) about 15m length.
I dont think the 6mm to a sub board is much use unless you are gonna put another rcbo protection at source as well.
at a push you could always use some 40mm solvent waste, plenty of room inside that,
and its black to match your other plumbing! :) no different to using 6" soil pipe for ducting underground IMO.
