J jonnymc11 Member Joined Jun 3, 2008 Messages 88 Reaction score 0 Dec 10, 2010 #1 am2 in 3 days.... Can people use this thread to post the 7 faults they had on their bays please. thank you.
sprocketflup BDSM SUB & SWAGFAG™ Supporting Member Joined Nov 11, 2010 Messages 2,659 Reaction score 16 Location Wonderland Dec 10, 2010 #2 that would be a bit pointless wouldnt it?
Zeespark Gold Member Supporting Member Joined Apr 24, 2008 Messages 3,940 Reaction score 11 Location Viva La Chesterfield, United Kingdom Dec 10, 2010 #3 Jonny, fault finding is a pivotal skill in this trade IMO. You will need to learn to suss out faults on your own. Basic testing will eventually point you in the direction of the fault to be found. AndyGuinness
oldtimespark Senior Member Joined Sep 12, 2009 Messages 171 Reaction score 0 Location Gwent Dec 10, 2010 #4 short circuit open circuit wrong connection switch failure load item failure , e.g lamp open circuit All basic test can be done with continuity,resistance and insulation resistance. One important tool is the ability to use your test result and use your electrical theory to check your results. ohms law and the regs
J jonnymc11 Member Joined Jun 3, 2008 Messages 88 Reaction score 0 Dec 11, 2010 #5 thanks oldtimespark, sprocketflup how is it pointless? getting a rough idea of the faults i will encounter? not really pointless, better than going in blind.
sprocketflup BDSM SUB & SWAGFAG™ Supporting Member Joined Nov 11, 2010 Messages 2,659 Reaction score 16 Location Wonderland Dec 11, 2010 #6 Surely the whole point of the exam is to see if you can do it blind - coz that is what will be happening outside of the exam room?
R retiredsparky Member Joined Apr 15, 2009 Messages 39 Reaction score 0 Dec 12, 2010 #7 Old Time Spark: There are no equipment faults only wiring faults.
B Bozzer Junior Member Joined Apr 10, 2011 Messages 5 Reaction score 0 Aug 29, 2011 #8 The three faults you will have to suss out: 1. Short Circuit 2. Open Circuit 3. Crossed connection i.e pass wires crossed ---------- Post Auto-Merged at 21:18 ---------- Previous post was made at 21:17 ---------- It never helps to be prepared!
R retiredsparky Member Joined Apr 15, 2009 Messages 39 Reaction score 0 Jan 22, 2012 #9 The Four wiring faults are: 1. Short cct 2. Open cct 3. Cross connection 4. High resistance Last edited by a moderator: Jan 22, 2012
