- Oct 22, 2010
- 14,621
- 1,171
I would expect part of the incumbent's remit , after she had brought me the beverage in a hand crafted crytal flute, would be to tidy away all the mess
Just saying
Just saying
Lovely bit of welding there John! Not just my opinion, I have a fair bit of TIG done for me commercially on ali and st/st and know a good weld when I see one! Keen to have a bash myself though. Just sent the cheapo buzz box back and got a full refund. Looking at this one:Welding...
You want full on then.. Use a 3.2 6013 rod with the rod connected to the positive. When you strike up, make a little weld pool and fuse both edges before you set off. Once going keep the rod jammed in the very corner, actually very lightly touching the plate. You will then most likely need a second run next to it [making the horizontal leg longer than the vertical] and then a third run in the "new" corner if you like, only this time a slightly, and i mean slightly longer arc length.
You want it to look like this...
http://i1178.photobucket.com/albums/x373/resistance87/GC136.jpg
http://i1178.photobucket.com/albums/x373/resistance87/GC137.jpg
john..
That was 3 runs, a 3.2 rod and about 112 - 115 amps on DC neg...
if he was going to 'buy' a motor, he wouldnt be bodging a 3 phase one onto it!Canoeboy said:When you burn the motor out you can buy a single phase one :slap
That's incredibly generous of you I must say! Hang fire if you would though. Working with VSDs I'm wondering how good one would be at handling the as yet unknown level of vibration! Let me get it running as is and I'll see how things look.Canoeboy said:On/Off - Ill have a look on Monday - May have a throw away(free) 1Ph to 230V 3Ph inverter if thats of interest to you ?
Aren't the petrol ones variable speed anyway, as in throttle control? Reverse I should be able to sort on the leccy one no problem. On the petrol ones I've seen them with an "idle" mode where you flick a lever and it just hump's on the spot!OMG a variable speed wacker plate. What next?
P.S our building control inspector's name is Waquar. I wonder what his nickname is at work?
but by the end of it he would only have a wacker. this way he has a welder & wackerBy the time you have bought the new welder etc, you could have just bought a second hand petrol wacker. But you would have deprived us of much amusement.
Changed that for you! :lol:but by the end of it he would only have a wacker. this way he has a welder that'll work & wacker that might work!
