wams
- Feb 29, 2012
- 19
- 0
IVe been asked by my local golf club to install a presence detector in the ladies locker rooms as they keep leaving the lights on. The secretary wants the simplest of work done, so I suggested installing an occupancy detector from the first light instead of replacing the switch with a presence detector switch but the current switch is a combined switch and Em light test switch.
the current light arrangement is t&e so after confirming that I paid Edmundsons Electrical a visit and he recommended the Titled detector. But the detectors instructions have 2 wiring scenarios, standard connection using 4 core mains cable and the 2nd scenario switching dc loads using 3 core.
I called Timeguards help line and they said I could use 3 core 1.5mm flex.
Im a bit concerned that Edmundsons and Timeguard are telling me different things, different to what the instructions say.
So I thought I would ask you guys. Can I use the current t&e arrangement or do I have to install 4 core from the mains panel, as it would be a nightmare of a job and that's one thing the secretary doesn't want. Plus I want to know if it will work before I start fixing the sensor to the ceiling and knock out the knock out and wire it and then it doesn't work.
i just want to make sure I can get my money back
wams
wams
