I've just installed an outdoor double socket with a built-in RCD circuit breaker, so I can plug my pond pump into it. However, because I don't want the pump operating 24/7, I have plugged the pump into a timer switch, which is plugged into a short extension lead going to the outdoor socket.
i.e. [OUTDOOR SOCKET WITH BUILT-IN RCD]-->[socket-->timer-->plug]--->[POND PUMP]
The middle section with the timer is housed within a waterproof box.
This worked fine, until the timer reached the cut-off time - and the break in power caused the RCD to trip.
Is there any way I can resolve this problem, so that the timer can controller the power to the pump without tripping the RCD?
Many thanks for any advice you can offer!
