Am I happy to actually HAVE some work? too right.......
But I nearly had conniptions when I saw the doorway to get into this afternoons working space:
Then the roof space itself ("floor" is plasterboard on 3x2 batten; forming the ceiling of the changing rooms in the hotel pool area).
Then navigate the steel beams:
use the ducting for balance, but don`t put your weight on it.............
The view of the exit - from inside
A bit of the plumbing up there......
(n.b. the whole area was lagged with rockwool on chicken wire, as the flue motor is in this room, and there are guest rooms adjacent; so noise needs to be suppressed. There is zero natural light, and the trailing light had to be run from down the hallway, and gaffered into place.)
n.n.b. For them who don`t know, or had forgotten; I`m just over 6`6".
n.n.n.b. BTW - the job? install motion sensors to the changing rooms, so the lights aren`t on all day. Nobody said BOTH changing rooms had the same supply, from a communal switch bank. Of course, its all 20mm conduit & singles, and you can only take out one changing room at a time!!!!!!
`tis done - damn, I`m good (and aching, sore, bruised, itchy, knaffered, et al)
KME
KME
