Notmy Realname
- Jan 9, 2013
- 2
- 0
I'm replacing an extractor fan in a small toilet. Since the walls are newly tiled and all the walls and ceiling are solid (plastered concrete), I don't want to run any more cables if at all possible.
The (very) old fan that I removed had three twin and earth cables attached, two are dead and one is permanently live. So using this live cable, I want to fit a new fan with an integral pull cord and a run-on timer, independent of the light, as I'm assuming this would minimise the wiring involved. To my surprise, this type of fan is quite rare, although I have found the Manrose Gold MG100TP which I think would fit the bill.
My questions are these: 1. Is a separate toilet, with no basin, classed distinctly from a bathroom as regards Part P? ie is this work notifiable?
2. Can I fit a fan isolator switch on the wall next to the fan at ceiling height?
3. Will I also need a 3A FCU?
