Transformer help
MalcyB
Oct 3, 2008
317
Hi All
You are my last hope.
Does anyone know where I can get one of these from?
http://www.rayuan.com/productcontent.asp?rskind=1&kind=10&id=32&view=1
It fits into a low voltage light bar, runs 3x20W halogen lamps. The company are in Taiwan. I have emailed, no reply.
I have had a look round for something that might fit but I am stuggling on the dimensions.
If anyone can help you will make an old man (not me) very happy.
Hi
Any 60-105 Watt Transformer will do the job, easily available at Local wholesalers
There is no ceiling, it fits under a kind of shallow wooden alcove over the top of some glass shelves.
Does it have to be exactly the same size, just had a quick look at about 30 different transformers and most will fit but are slightly taller. If not fit a small one next to the light bar or use a decorative one if it is an issue.
The critical dimensions are the width, no more than 42mm and the depth, no more than 19mm.
Length I can get away with anything upto 180mm
There is no room outside of the fitting to put anything.
Thanks for all the suggestions, I think I'm going to have to tell him he needs a new fitting.
