Use the meter (set to dc or ac depending on the transformers output) on the little power plug at the end of the lead and see if it gives the correct voltage out that it says on information sticker on the plug body.
Yes. However it may read a negative voltage if it is a dc output (is it?) as either the inside or the outside can be positive depending on the configuration.
