TT minimum size protective conductor
Theorysparky
Domestic Electrician
Feb 18, 2008
4,232
Dont do much TT stuff but at 65m away from the house it seems prudent this time
10mm line conductor
looking at table 54.7 pg 162 BGR
It comes out at 10mm
it reads right
can someone confirm i am looking at the right table
I could just put 16mm in but thats lazy,,,,,didnt spend
For TT you should be OK with 6mm but 10mm is what I normally would use anyway
Why 10mm Theory?
Think about what the maximum fault current could be and then calculate to that,,,
but then again you'll probably have to go bigger due to having to add mechanical protection,,, easier to just increase the size;)
I'm putting in a 16mm sq main bond to the incoming water tomorrow as there will be a borderline section 710 install on the premises.
