Nicky Tesla
- Apr 30, 2008
- 1,671
- 19
Hello i am to replace a DB soon where there is currently a separate fused isolator and an old dual tariff boost switch, for the water heating element. The E7 time comes from the separate E7 radio telemetry switch meter and therefore has different supply tails than that of the main board.
The element receives its power from the boost switch from either of two sources, the main DB or the SFI then on to the element via a single T&E.
The problem is, how can i wire the new DB so that the RCD main switch doesnot go off, when the other supply comes in, which was not a problem before the need for RCDs. I assume that the old E7 switch may have a common neutral terminal which may cause this.
My thoughts are a smaller seperate DB, within it 2 main switches feeding 2 seperate 15A mcbs, which then go straight up to the old switch. Then the cable to the element coming back down to a 61008 RCD and back out again for the final to the element.
This seems a bit OTT so can anybody think of a better way ? ?:|
