Was on a job today and was asked to look at why some spotlights upstairs weren't working on the dimmer.
Before I describe it, I just want to say I know there's probably not enough info for someone to tell me what's what, but hoping someone can shed some light on the different methods of achieving two way lighting, as I only know one and what I saw isn't it.
Upstairs: 2 gang dimmer. On the right, the spotlights, on the left, stairway lighting.
Downstairs: 2 gang dimmer, on the left downstairs light, on the right, stairway lighting.
So, when I get there the spots aren't working at all, I take off the faceplate and I see: Left side Common: brown, L1 Black, L2 Grey. But the grey is connected to the other gang on the same switch (I think it was on L2 but it might have been on common.
Downstairs, old colours. Common yellow, L1/L2 red and blue.
I'm going back at some point to try to get it working. I have no idea what the hell is going on with it. Both dimmers do control the stairway lighting, but in a really odd way. On turns it on and off, the other can dim it but only when on at the bottom. The brown and black on the spots doesn't seem to work at all, perhaps it was taking it's live from the other gang -I took the cross link out as it seemed a bit odd.
Is it correct that you can only have one dimmer on controlling a light, is that a regulation?
Any idea how this may have been wired? Could just be the person who did it had no idea what they were doing, or it could be something I've just not seen before.
Thanks in advance.
Thanks in advance.
