SoulkillaH
- Dec 2, 2009
- 52
- 0
Hi !
2 days ago i had to change a pump for a underfloor heating system.Everything is working fine, but the rooms are not heating enough.
I said that because is a 3floor house, every floor with a pump.
The ground floor and the 1st level are ok, but the basement is still cold.
I check the pipes and both flow and return are hot ,but not the rooms.
Is that because is a basement or because the system is not well balanced?
Thank you!!
Thank you!!
