If working on a new build house , which I am, am I correct in assuming that I omit the VAT from my invoice to the builder, as new build is zero rated. ?
It doesn't work like that unfortunately. They wont pay it back because you should not have charged it in the first place.Don't think it matters if you charge VAT he will get it back anyway.
WrongDon't think it matters if you charge VAT he will get it back anyway.
You dont need to.So you tell the wholesaler not to charge VAt on materials as they are going into a new build?
This is incorrect. The suppliers have nothing to do with the build, You still pay suppliers in full. If a job is zero rated then you cant pass it on so the VAT people pay it back to you. You need the planning permission number. Also note there is a difference between zero rated & exempt.You dont need to.If the build is 0 rated then you dont charge VAT, the fact that you had to charge it otherwise must mean you are VAT registered. therfore you can claim back the VAT from the supplier
That is what I was trying to say, maybe phrased it badly.This is incorrect. The suppliers have nothing to do with the build, You still pay suppliers in full. If a job is zero rated then you cant pass it on so the VAT people pay it back to you. You need the planning permission number. Also note there is a difference between zero rated & exempt.
but is the subcontractor to charge 0 VAT, or just the contractor?Having read the link to HMRC from Boating Billy...(Thanks) it appears that I don't charge the builder VAT , he supplies the Mats so its labour and travelling only .
