EndlessNites
- Sep 5, 2019
- 3
- 0
I had some metal chandelier light fittings installed by an electrician 15 years ago (1 ceiling light in the dining room and 2 wall lights and ceiling light in living room). For a while now I can feel a vibration from the ceiling light in the dining room when touched lightly, as if there is a charge running through it. It vibrates whether on or off at the wall switch. I've checked the fitting and wall switch for loose wires and the earth.
I noticed it in both my living room wall lights last week too but the vibration stops when switched off at the wall. 1 has a stronger vibration than the other, they run off a 2 gang wall switch with the main living room ceiling light which doesn't vibrate (not at a level that I can feel anyway). I'd taken one of the wall lights down to change, then didnt like the new light so put it back up ..I'm not 100% sure if they were both vibrating before but the 1 I didn't touch vibrates too. I've also checked this switch for loose wires and earthing.
Today I've plugged in a Innr striplight, put it in an aluminium diffuser and that is also vibrating slightly. I've noticed it on the metal casing on the back of my TiVo box too.
Is this just normal or is my house wiring dodgy?
I'm starting to replace my lights with smart bulbs so they will be permanently switched on but I'm switching them off at the moment incase something is wrong.
Thanks.
Thanks.
