Racricket
I'm with steps on this one, why would you use the hot water side?
You cannot use a 2 port valve on a Y plan, because then it isn't a Y plan. It is a physical impossibility.
I know I'm just speculating as to what has been done to resolve it..
There are various ways of using the stat, which actually has 2 thermostats in one housing. TBH if you are not really familiar with heating systems in general (which it doesn't sound like you are) then it is probably best to leave these types of things to those in the know.
I've done plenty of combi boilers and numerous s plan systems all without problems but this set up and the reason it wasn't operating puzzled me..
Would you walk away from a job if it wasn't something that you were totally familiar with or would you look at the diagrams and try and work it out ??
Without seeing the entire system I couldn't really say what you did wrong exactly, so I will not try and guess how it should have been wired.
