- Feb 5, 2009
- 5,612
- 1
One a job at the moment where the customer wants flatscreen put on chimney breast. No problem in getting socket behind TV when on fireplace but not sure on the aerial situation.
It had sky before and i understand a little about it but never touched virgin.
There is the main aerial in the loft with a feed down to stairs under cupboard which ive fitted a booster to power the 5 aerial points around house. One of these coaxs goes to front room in corner where TV is at present. Another coax goes from this corner out to the kitchen coax outlet.
If I cut the ends off these coaxs in corner of front room and join them i will have standard TV (freeview) on the kitchen TV which customer is happy with.
What i need to ask is does the virgin need a normal aerial or is it like sky doesnt need one?
Also how do you guys normally go about getting cables up behind the TV ie, scart leads.
I was going to run some conduit concealed where I can get these cables behind the TV, is this the norm.
Any info appreciated as always
Cheers
M4tty
Cheers
M4tty
