Today I went to a job where there has been a flood. They need to get the dehumidifier going but the sockets wouldn't work (on an rcd which kept tripping due to water). I have temporarily moved the sockets onto the non rcd side and they dont trip. My socket tester is saying they are live but when plugged in nothing is working. Any help please guys?????
If the RCD is tripping then obviously there is a fault on the circuit.
Putting a known faulty circuit onto the Non-RCD tested side of the CU is daft to say the least...
An analogy would be..
My car's breaks are faulty.. (pads are worn right down..)
But my neighbour want to borrow the car..
So I think.. AH I will go and pump the tyres up..
That should be ok...
Then lend him a car with potentially fatal breaking accident waiting to happen!
Solutions:-
SOLVE THE CORRECT PROBLEM!!
the problem is NOT I must get the dehumidifier on...
the problem is...
I need some SAFE electrical sockets to use at the property.
so..
1) Get a proper tester that can correctly evaluate the TRUE level of damage to the electrical installation
A plug in polarity tester is NOT an appropriate tester for this sort of problem.
2a)
Identify the faulty area(s) of the circuit..
get it/them fixed..
Plug you dehumidifier onto a KNOWN good safe working circuit!
OR
2b)
get a petrol generator and power the de-humidifier off that.
Your phrase "you went to a job"..
Does this imply you are actually a qualified electrician?
If yes...
surely you grasp the urgency to do all the correct tests after probably water damage....
I personally would treat it as a new circuit and test EVERYTHING!
Then decide what can or cannot be used.
