water causing havoc
My dads house was flooded due to a burst water main few streets away and water came above the socket height . The electric was turned off for the whole area until all dried out. When it was put back on all worked fine. (bs3036 board no rcds) I changed board for assessment few years later and all cables tested out fine so you may be lucky
Long term damp defo causes problems with corrosion of internal workings of MCbs, switches etc etc. Have been working this week on an electrical supply to 4 flats in a leaking cupboard (leak pointed out 1.5 years ago, but no action taken). Meters (which look ip rated) - knackered. Corrosion on busbar of landlords CU, meter tail blocks - green. But you could definetly feel isolator switches and MCBs are corroded. Ergo would probably not operate correctly when needed. Hence I've ripped out and replaced the lot cos I don't trust any of it. I would also now not be happy to re-connect accessories as per the OP scenario - you can't tell what damage has been done internally.
Ryefield board was also ripped out by western power - guy doing the work was telling me that because they use aluminium for box and some parts inside, the newer Ryefields are prone to internal corrosion in damp atmospheres. The old units made form steel and copper last forever apparently.
