- Feb 5, 2009
- 5,612
- 1
Looks that way mate
They're fobbing you off mate. I work for Southern Electric (In the Kent/SE Lonon area) and although we can do a ze test for you we're not allowed to change the earthing arrangement as that's down to the dno.Just rung edf and they said that its not their responsibility and i need to contact the energy supplier who will send a meter man out who will loop test it and sort the earth out. Not sure if ive been fobbed off. What do you guys recon. I know about ESQCR regs saying that if they supply a earth they have to maintain it.Think next step is to call Southern Electric and ask for them to come round and do a loop test and sort earth out.
I know a jointer that worked for them for years and did his apprentiship when it was Eastern electric he got fed up with them and now works for a company that does a lot of there work.Found this on iet forum and thought was relevant to this post re getting passed from dno to electricity supplier to dno etcDown here in EDF land the whole sytem seems to be to be out of control. With the fragmentation of the industry and the process of disposing of competent knowledable people from the industry to jack up the profit whilst cutting back on the service provision leaves the network in a sorry state. The current DNO known has EDF has had numerous name changes and owners and is currently up for sale and has been for about a year. Consumers ringing up the "help desks" will get buck passed around DNO departments to the meter operator and the supplier and round again with all denying resposnsibilty and refering the consumer to one of the other parties. In respect of cut out seals and meters I have been to houses with no meters to PIR the installation. When I arrive the owner says have you come about the meter? They have tried to get a meter as they are worried about getting a huge bill but again get passed around the system and promises to attend site are not delivered. I know of "help desks" telling consumers to get an electrician to convert their own installation to TNCS when they have a bad TNS Ze.
Rather than trying to get EDF to provide a service in to a property it is not unknown for the consumer to pay cash to a contractor to do it for them same day rather than spend a months pleading with EDF to do it. I read in their in house magazine where they had cottoned on to the illegal service connections and were having a big drive on prevention and detection, stable, bolted, horses and doors springs to mind. They might want to start at all the illegal travellers sites that have their own DIY service connections.
So electrical contractors pulling cut out fuses to do their work is the least of their problems. They perhaps might want to focus whilst they are at it on the thousands of installations with fused neutrals, unearthed cast iron heads and decayed service cables.
I had no seal on my cut out fuse for 25 years, probaly longer as it was not there when I moved in, which was handy when I changed consumer unit for the 1st time,when I rewired the house when I moved in and years later when I fitted an isolator and new split load board. It was not until a couple of years ago I had a new meter that the cut out was sealed. I did check the polarity after the meter change as it is not uncommon for the wire, fire and f**k off meter changers who are in and out in a few minutes to reverse the polarity. A mate of mine who is a school teacher and former electrical engineer had a meter change. After his daughter noticed a flourescent light had a swirling light in the tube when switched off. He suspected the meter change from the off and confimed reverse polarity and then his problems started trying to get someone/anyone to come to site to confirm his findings and rectify the fault.
Thanks mateHi So have I got this right?
This installation is fed by Lead sheathed cable coming up from under floor and next door is fed off this cable cut-out. Or is it the other way round?
Its the other way round. Next door have got the incommer with their earth by a BS951 clamp where the earth is normally sweated on
This was a common way of feeding semi's . So you will find they both should be TNS with a link cable thru wall.
Ive had a look next door and cant see any other cable coming from the incommer apart from next doors bs951 clamp. There is a cable which looks like its coming from next door but goes to the lead water pipe. As per picture above if you can make it out mate
You may be able to get a new supply put into the one that is linked as each dwelling should have an independent supply
Now if it happened that the one linked off next door lost its earth then this would be a dangerous condition reportable to DNO as an emergency.
You would have visit from a DST who would assess and arrange to have new supply cable put in.
Been round there again today and went next door and his earth is via ec15 tenby clamp. My dads Earth is via his lead water pipe only. I continuity tested for his clamp to my dads earth and the reading were in kohms. Next door has said he doesnt mind me feeding some 16mm earth through the wall with the looped supply cable and onto his clamp (providing its within regs)OKSo your Dads earth should come from next doors Clamp or MET as well.
Simple option if ok with next door is to put a 16mm 6491x thru wall.
Hey presto you have TNS as it was ment to be.
Cheers for the advice mate and if I done this the assessor would be fine? and if someone did disconnect it next door it would still be earthed through the water pipe like it is now with a ze of 0.19 ohmsHow would he know? The DNO should have provided a link when installed along with the L and N.Suggest providing earth block MET next door if it does not have one and pick up 16mm link earth from there, don't touch BS591 clamp on sheath other then to GENTLY check it is tight. It makes a big bang if you over tighten and squash the lead into the Live conductors!
Thats why they should not be on there in the first place but commonly are put on by DNOs.
In effect you are doing EDF a favour in improving the Network, you should send them a bill, but perhaps not.
