Robin Spark
- Aug 30, 2009
- 1,424
- 0
Do you come under South Staffs Bacon? I have just found the link below which says that - South Staffs Council charge
Napit do the just 8 scheme or used to. However it cant be under a business name and the work must only be for friends/family and not for business purposes.Dont/didnt elecsa or somebody do a scheme called "just 8" or something like that. Designed for those in the trade that do the odd homer here and there, meaning they can then notify upto 8 jobs a year.
That can't be right , can it ? What if you carbon monoxied someone , you still be held responsible , surely ?mmm, interesting point by prodave tho?is it like gas where you can do whatever you want if there is no financial gain????????
A good point Noz , I've seen them too , but also seen first class jobs by guys who know what they're doing but not registered . Presumably you just refuse to pass off any dodgey work in the same way as the NIC man that the LBC send round.The reason why they charge so much though is because they don't want the bother of Part P,, and anyone who is serious about being an electrician, doing domestics should really look at being registered as this should make them cheaper than going the LABC route!As for the idea of using a registered guy to "sign off" the part p aspect instead of the LABC,,,, maybe that is something that should be looked at by the ODPM and scheme providers? Most of us understand that there are lots of things wrong with part p and the way it was implemented
And just because someone is an electrician does not make them aware of all the regulations that apply to dwellings... I have seen some really bad jobs carried out by industrial electricians I houses
You can't do "whatever you want" with gas for DIY. It still has to comply with regs, and you must still be competent to do it. It's just that if you are doing it say on your own house, then you don't need to be Gas Safe registered.mmm, interesting point by prodave tho?is it like gas where you can do whatever you want if there is no financial gain????????
sorry Dave, yes that is what I meant,You can't do "whatever you want" with gas for DIY. It still has to comply with regs, and you must still be competent to do it. It's just that if you are doing it say on your own house, then you don't need to be Gas Safe registered.I did the gas work in my present and my last house, and in both cases building control had no problems signing the building work off as complete. But I must stress you must be competent to do it, and must still do it correctly.
