Who do i have to notify when fitting new db?
a1pacino
Mar 15, 2008
118
Hi guys,I have just bought a house and its got an old distribution board so I am going to change it to a new one,I'm not registered with any schemes as I am working in maintenance at moment, I have 2330 L2 and L3 and 17th Edition. Who if anyone do I have to notify about this work?
Many thanks in advance
thanks for the quick reply Andy, am I right in thinking that I do not need to be Part P registered as I have 2330 L2/L3/17th Edition and that I can test and inspect the property myself and sign it off as a competent person. Also does it cost to notify LABC?
yes it costs to notify. you either need to be art p reg to self cert, or notify labc. being qualified makes no difference if your not part p reg'd. but it may make notifying labc easier
as far as i am aware the only people who can sing off work is......
the people who are approved with a scheme eg nic eic and napit.
and let labc know about it as previosy said
cheers
Hi, Al Pacino , As the others have said , under this wonderful government scam, oops sorry, scheme, you need to be registered with a competent persons scheme or you have to ask your local Building control to pass it off . In Birmingham they charge around
as far as i am aware the only people who can sing off work is......the people who are approved with a scheme eg nic eic and napit.
cheers
Your first statement is no strictly correct!
Do NOT get confused with the TWO certificates:-
1] An appropriate Electrical certificate as per BS7671.
and
2] a Building regulations Part P compliance certificate.
Any competent person can install test inspect & sign an appropriate electrical certificate regarding the work they have done.
It is the Approved scheme member or LABC who will sign ('actually register detail on-line') for the issue the second one.
:D ;)
Hi guys,I have just bought a house and its got an old distribution board so I am going to change it to a new one,I'm not registered with any schemes as I am working in maintenance at moment, I have 2330 L2 and L3 and 17th Edition. Who if anyone do I have to notify about this work?Many thanks in advance
Notify LABC
but tell them you are competent and will be doing your own testing & certification.
You issue them with a copy of your EIC..
Providing they are satisfied then they will issue a Building regs compliance cert.
See Page 11 of approved document P
"Certification of notifiable work"
paragraphs
b.
1.21
1.22
& 1.23
gives all the procedure! :)
Approved document P is downloadable...
theres a link on the forum somewhere???
shh!!!
I hear the sound of Patches little hooves tramping through the soft snow as he goes off find a link! :) :xBlushing
:coat
If it helps any further, I am not a qualified electrician only part P compliant and I do not belong to any scheme. All I do is notify LABC and include a Cheque for
Andy I have tried three times to reply to you but having problems at the moment either computer or site ??
Computer. I can see your replies.
As I mentioned in the other thread, clear all your cookies etc... I would imagine that is the root of all the problems you are experiencing here.
