O.K.
Thanks for your input.
I'm using three different kinds of battery. They are all 'Duracell' batteries.
One is 2000 mah saying to charge at 200mA for 16 hours
One is 2300 mah saying to charge at 230 mA for 16 hours
One is 2650 mah saying to charge at 270 mA for 16 hours.
My charger is an eveready charger model EVVC which charges at 2.8V 170mA-200mA charging two batteries at a time.
Seems to be under rated for the two of the battery types I've got but it seems to handle them okay though. I've got recharged 2650's in the camera right now.
The camera specs don't seem to care about which AA's you use.
I recharge only after they've failed in the camera - so I guess it is possible that the camera has failed them after not sucking enough juice out of them. Arguing against that is the fact that recharging them and then trying them will see them apparently work okay and for the longest time, and shooting video which is the hardest task for the camera.
I don't know how to test the batteries during their time 'in waiting' in the plastic box. I have a cheap digital multimeter - would it be sensitive enough to measure them in some way or other that would indicate if they're losing charge or not? It has a current measuring function, just barely, if I remember right from when I got it and read the instructions you can only use it for a couple of seconds or something.
I have heard - talking car batteries - that merely measuring voltage isn't at all good enough. That a battery can tell a multimeter that it has sufficient volts on hand only to fail to be able to deliver sufficient current when a load is applied. I don't know how true that is and I don't know (if true) if it applies to these tiny AA batteries.
There are vague memories of static electricity tricks with plastic combs and rubbing on cloth. This plastic box sits inside a cloth camera case. I tentatively surmised it to be just possible that some kind of static electricity thing was happening that could somehow or other drain the charge from the batteries. But, of course, that was all wild speculation born of my ignorance. It is what caused me to post here.
I'm now quite ready to believe the problem lies somewhere in my charging or whatever but if anyone has any other theories I'd like to hear them.
regards,
ab
