I was doing a CU change the other day and found that someone had installed a rod and connected it to the MET....WHY????
There was no problem with it, the Ze was 0.21ohms...
ok the block might have been loose, you know where they just screw the block over the top of the plated copper band, but that was easily fixed (trim, fold and stick in MET hole)!
