I am really puzzled as to the "solution" to fires in consumer units that have triggered the installation of non combustible units. As someone who worked in an industry that had great hazard potential to both product and people the emphasis was on prevention and we had extensive training in problem solving and how to develop preventative solutions. Putting a consumer unit in a metal enclosure will not prevent a fire only contain it and the success or otherwise of this will no doubt be down to the quality of the installation. So it seems perverse to me to take this approach instead of understanding what causes the fire in the first place and correcting that.
Some theories I have come across are
1. Electricians not tightening the incoming terminals enough,
2 Using power drivers and breaking the screw using too much torque,
3 Quality of the cable tails in that the copper "relaxes" and terminal becomes loose.
No doubt you can add others
I read an article the other day by an electrical engineer that the incidence of fires in CU had increased 5 fold over the last 5 years. I presume it is true and if so there must have been some changes during this period to have resulted in special causes which should be put right.
Are the main switch terminals man enough? compare the terminals in a 100 A Henley block with the terminals in the main switch and you will get my drift.
