I just purchased a catering trailer that is already wired up.
The road side supply is a 32amp (commando socket).
Consumer unit in the trailer is fitted with 1 x 63amp / 30mA RCD Incomer (Trip Switch) plus 1 x 32 amp Miniature Circuit Breaker (for sockets) and 1 x 6 amp Miniature Circuit Breaker (for Lighting).
I thought it a little strange but the external socket on the trailer that will connect to the road side supply is a 16amp commando socket.
I was told that the wire from the external socket to the consumer unit is 6mm and I expect the wire running to the sockets from the consumer unit to be 2.5mm.
Given that I need to be able to plug in to the sockets, appliances that will collectively draw up to almost 6000 watts,
1. Do I need to change my external commando plug from a 16 to a 32
2. If the wires to the sockets are 2.5mm, will they fry when everything is plugged in and do they need to be changed to 6mm?
