Easy to get around this one.my mate had same prob, he got a xp disk it worked and still does but now its coming up with illegal version
Why do you need to do this?Have lost my original XP install disck and need to format my 2 pc's. Does anyone have a copy they could spare (either on disk or to download)?
Make sure your windows updates doesn't install the pesky Validation Tool. If it does and your key is not proper/duplicate you will get the warnings.go on?
Used the same XP pro disc to install now on 4 pcs and each time used the windows key original to the pc and not the disc. Never had any issuesI thought the licence key was specific to a disc?
Not so, otherwise the replication costs would be astronomical, I used to work for an M$ trade distributor, so on this point I know the scoobyI thought the licence key was specific to a disc?
It would have to be a motherboard change, as once the key is activated it is tied to the BIOS on that PC, but from memory this only kicked in after SP2Not all computers have installation discs. Some have partitioned Hard Drives with windows embeded in one of the partitions. These computers come with a product code. This is used to generate a licence key.Sometimes if the product is reinstalled too often, or if major hardware changes are made to the computer a new product code is required to generate the licence key. There is a phone No. on the product registration page to be used to obtain this new key.
Computer manufacturers and retailers may have a disc that they use to install or re-install windows on numerous computers. They do not always pass on the product code to the customer. In these instances a new product code is obtained in the same manner as stated above.
Replacement discs can be obtained from Microsoft, for a nominal fee.
I think that's how it works, it's been a long time since I had dealings with this sort of thing.
This would be true for a corporate key, or student edition keyUsed the same XP pro disc to install now on 4 pcs and each time used the windows key original to the pc and not the disc. Never had any issues
Nah, it's only specific to the version (eg, XP Home OEM, XP Home Retail, etc)....although you can sort that out by editing the setupp.ini file on the installation CD and then patching wga.dll after you install.I thought the licence key was specific to a disc?
