- Nov 30, 2008
- 929
- 54
I think kerching maybe right with the terminals
Hello, yes tried almost every configuration. The first was as you said as its most logical and then second was when I took the picture.At the risk of repeating what I said
Have you tried what I said?
looks like i was right, it is a 2g2w switch used with a common switch. wire as i mentioned earlier. if it doesn't work, swap the wiring between L11 & L12Thanks for your help - this is the front without the face plate.
Thanks Andy - just to be clear I should wire as below but also add in a link to join L1(1) to L2(1) and also add in a link to join L1(2) to L2(2)?looks like i was right, it is a 2g2w switch used with a common switch. wire as i mentioned earlier. if it doesn't work, swap the wiring between L11 & L12
it will never work without links unless it has them internally but i don't think it has
It’s a dual two way switch mechanically linked so both switches work together from a single toggle. With the addition of a couple of links (see my earlier msg) the two 2 way / changeover switches can be made to function as an intermediate switch. The manufacturer should have included a diagram or pre linked it.looks like a two in, one out change over switch
