Wiring dilemma
mainline
Feb 9, 2022
130
83
A bit of a dilemma / argument with the way the Project manager, who has supplied me with a wiring diagram that he's done for control of hot water in a block of 4 cottages.
The cottages are pme earthing, there are 2 phases split between the 4 cottages.
There needs to be a call for heat from 2 cottages which are on a different phase to the boiler, his wiring brings the supply in to a wiring centre to supply the zone valves / and tank stats.
There are 2 immersion tanks, one downstairs and one up, both zone valves are in the same location with a cable for the downstairs stat tank having to run through the house to the upstairs one.
He is adamant that i wire it the way he wants, he's installed 2 5 core cables to the wiring centre from the cottage to the wiring centre which there is totally no need to do as it only requires the call for heat to the boiler.
Wiring it his way will mean that both the tank stats, zone valves etc will all have a supply + phase on them from another location.
The prospect of not being able to isolate this wiring centre valves/stats both up and downstairs, i can't see as being right when either a no volt 2 channel programmer would do a far better job with a lot less wiring and would mean that everything apart from a single connection would be from the same supply.
There is a bit more thrown into the mix as one of the cottages has to use a wireless switch to be able to turn off the bio mass hot water. He's provided one with an SL output which is totally useless as that SL would have to be wired from the other supply along with the earth and neutral from the other location.
I'm thinking on Monday to refuse to do this, am I right in doing so ?
Thoughts, questions ?
I'm on the same page as you.
Doing it his way....
1 - multiple phases within an enclosure, 400v label.
2 - everything would need to be plastered with warning notices about how to isolate and work on this system.
3 - the occupant can't safely isolate things in their property
4 - the poor chap changing a zone valve or a cylinder stat isn't going to expect the supply to come from another place.
There is a an RF-solutions product for wirelessly sending a switched live a long way, which I've used in the past when a builder thought it was a combi
and cut a load of wires. (There's even a two way one designed for pump over-run).
I'd be seriously temped to adopt the idea that the wiring centre is supplied locally, the zone valves are supplied locally, and the boiler fire is wireless, meaning everything can be turned off as expected.
It could be done simply by using a contactor on the call for heat along with an isolator, the rest would then be on the local supply.
The stats on the immersion tanks are open back things where you can see the bimetal strip stats are only held on by the sprung wire.
These are holiday cottages, and it was only the other day that he gave me 14 pages of eicrs with loads of c2s from 5 yrs ago because he forgot !!.
I missed there was cable run already, it's a no brainer to me to do it that way.
I think the principle to keep in mind, however it's done, is there need to be means of isolation under the control of anyone working on it.
Doing it his way this becomes silly and complicated, e.g. a lockable isolator the boiler end, or a 4 pole isolator where it comes into the cottage!
You could point out that accessing the boiler property to work on another one will inconvenience guests in the future.
Your way it just works..
You way it does itself, even if the contactor coil gets energised you turn the whole lot off with one FCU as everyone would expect and nothing would pass through the contactor.
We had an argument about it, and he stormed off, saying "just do it the way I've told you" I said you can do it as I'm going home.
2 mins later he came back in full apologetic.
I started to wire it but realised he wanted another switch in the CU to turn the other valve off for when it's not being used.
And a wireless switch in the other cottage to do the same thing.
These are needed because he didn't get a 2 channel programmer, so it's not able to time the hot water or turn it off. (He said we don't need a timer) but we need to be able to turn if off with a switch in the CU next to the Immersion one, hence another run of cable upstairs to the wiring centre.
The point is, do you think I'm right in refusing to do it his way.
The point is do you think i'm right in refusing to do it.
If he can't be reasoned with and it comes down to an ultimatum of 'just make it work my way' then yes I'd walk away.
If he lets you add suitable means of isolation to make it safe then I'd begrudgingly accept that.
(at that point it's work arguing that less isolation is needed your way for comparable costs)
I am of the opinion that doing it his way just creates too much of a risk.
But can't think of anything in the Regs to say it can't be done his way.
Bear in mind they are not just another supply but also another phase which is going to 2 zone valves, 2 tanks, and 2 switches in other locations.
The N L E of the other supply is also being brought into the wiring centre from the other location.
My wife has just stuck an Agatha Christie thing on, so I will gladly grab the regs book and have a think
Isolation, multiple phases, multiple sources of supply, and linking earthing systems are all possible areas of interest.
Run each switch/ thermostat to 12V double insulated power supplies and cable from the outputs to the boiler room Diode each (low voltage isolated, non grounded CE) supply cable together for extra points and connect it to a Mains rated relay by the boiler. If the cables are long use a 13.6v PSU in each location to avoid thick cables
Note of explanation at each end of the cables. Done
Am I right the wiring centre would only have the other supply in it, coming from the boiler?
I'm as not concerned about the different phase per se. after all we are used to finding multiple phases behind a light switch in commercial buildings.
For me it's all about isolation, and the fact it simple isn't how anyone would expect it to work.
My considered view is that I think it would comply if there was adequate warning notices at consumer unit, by wiring centre and zone valves, and at both immersion tanks, and an isolation point before the wiring centre.
Some regs that I think are pertinent:
132.15.201 Effective means, suitably placed for ready operation, shall be provided so that all voltage may be
cut off from every installation, from every circuit thereof and from all equipment, as may be necessary to prevent
or remove danger.
134.1.7 Where necessary for safety purposes, suitable warning signs and/or notices shall be provided.
514.11 Warning notice: isolation
514.11.1 A warning notice of such durable material as to be likely to remain easily legible throughout the life
of the installation shall be fixed in each position where there are live parts which are not capable of being isolated
by a single device. The location of each disconnector (isolator) shall be indicated unless there is no possibility of
confusion.
514.15.1 Where an installation includes alternative or additional sources of supply, warning notices shall be
affixed at the following locations in the installation:
(i) At the origin of the installation
(ii) At the meter position, if remote from the origin
(iii) At the consumer unit or distribution board to which the alternative or additional sources are connected
(iv) At all points of isolation of all sources of supply.
