Wiring from Hive Smart transmitter to Worcester floor standing boiler
JDA46
May 14, 2019
2
I am interested in fitting a Hive Smart heating system to my Worcester Greenstar floorstanding  boiler. What cable do I need for this to connect the boiler to the Hive transmitter?
I do love the sales bull ' smart heating system'  - it's a progammble thermostat that replaces a standard thermostat :^O . Now I've never fitted a HIve, but if you have a thermostat the existing cable is probably sufficient, failing that a 1mm flex 2 or 3 core is probably sufficient - should have info in the intsructions.
The Hive transmitter fits onto a standard Honeywell timeclock backplate.
The Single Channel (combi) wiring is :
N  |  L  | Common  |  Heating Off(NC) | Heating On(NO) | Unused
The Duel Channel (conventional) wiring is :
N  |  L  | Hot Water Off(NC)  |  Heating Off(NC) | Hot Water On(NO) | Heating On(NO)
