Aye that's what I was thinking too.At the moment, I 'll say 5 cores (not including CPC's and neutrals looped separetely at each fitting) ie 1 feed to the switch, commons all linked together and then 1 core out to each light fitting.However, you can get wireless units that need a sender at each light fitting, but not sure about a 4 gang switch.
Cheers, I'll take a look at those out of interest.Just had a look on TLC they have GET sphere lighting controllers which is a battery operated controller either 5 or 8 channel options. But you would need a reciever for each light fitting if you wanted them controlled individually. This is an expensive option though!However, you wouldnt need any cores at your existing light switch!
Providing all switch wires are correctly identified, knock yourself out.---------- Post Auto-Merged at 23:39 ---------- Previous post was made at 23:38 ----------
Cheers
---------- Post Auto-Merged at 23:41 ---------- Previous post was made at 23:39 ----------
is it acceptable to use any colour core as switched live as long as the correct colour band is installed at termination points?
Lol no, just thinking if I had to double up on cable I.e. 2 x 3&e. But then when I think about that I've answered my own question lol.You cant oversleeve a cpc if thats what you are thinking.
Nope, lights are already in, but it's just a garage anyhow.I assume by the questions this is a DIY project? if the lights are being installed in a kitchen they may also need a building regulations compliance certificate issued.Doc H.
