Hi, i have recently been on a honeywell course to learn how to wire central heating systems, all went well just have a few questions stillWhat is the most economical reels of cable to buy? 3 core and 5 core? also im not sure what currents most systems draw so what is the common size cable to wire it in?
the people on the course insisted the room stat and cyclinder stat didnt need a cable with earth to be used and just 2 core, is this correct? i always understood you should just terminate the earth at either end even if class2 fittings are used
I've been thinking about doing the free Honeywell course too, mainly for the 'kudos' so I can make myself more 'saleable' to local plumbers. I already do work for 3 local plumbs and wouldn't mind expanding this side of the business. If I do say so myself, I'm generally quite good at wiring CH systems and fault finding.
However, if this course leaves you with so many basic questions, I'm not sure I will bother. Seems hardly worth going. OP, could you give us more idea of the course content and how you found it?
---------- AUTO MERGE Post added at 09:07 ---------- Previous post was at 08:59 ----------
No, it isn't.
411.3.1.1 para 4:
A cpc shall be run to and terminated at each point in wiring and at each accessory
..(except for pendants)
Now, when you say "the people on the course" do you mean the tutors or students?
---------- AUTO MERGE Post added at 09:19 ---------- Previous post was at 09:07 ----------
I use a combination of 3, 4 and 5 core flex, all 0.75mm.
http://www.screwfix.com/search.do;jsessionid=OAW5QZPNI2CWUCSTHZOSFFY?_dyncharset=UTF-8&fh_search=95721
http://www.screwfix.com/search.do;jsessionid=OAW5QZPNI2CWUCSTHZOSFFY?_dyncharset=UTF-8&fh_search=20292
I buy mine from Edmunsons though.
Which you use will obviously depend on which item it goes to. FVor example on a Y plan the programmer needs 6 live cores, so I use a run of each of 3 and 4 core. The tank stat requires 3 live cores, so I use 4 core (3 live cores plus cpc). And so on.
If it's a gas boiler then you should be fitting a 3A fuse. The highest consumption item in the system is generally the pump at about 80 to 100W. For oil boilers a 5A fuse may be specified ('cos the boiler has an oil pump too).
On the subject of pumps, why not try selling the client one of these:
http://net.grundfos.com/doc/webnet/poweredby/gb/alpha2.html
I'm going to fit one to my own system soon. They cost about
