may have to look at that. the box often has only 10-40% space left. gets lots of stuff left there unwatched for weekshave you defragmented the drive recently?My mum had this problem and a defrag solved it
Your box may have the same problems as Apache.whilst were on about sky boxes...my sky + likes to crash every so often when i turn it on from standby. it just freezes. sometimes comes back to life after a few mins, other times need power pulled.
also, it often says no signal received when turned on. turn it to standby and back on, and everything is normal, or if i go to check signal, both are as should be, then go back to a channel, all works.
any ideas?
I guess you could have a look to see if any of the screws / bolts that enable fine adjustment are lose at all.321 and 322 are bad!BBC is fine. My worst are 365,366,367,372,374,376 & 382 in my music 'loop'
I have no spare box
The 'Signal Test' page gives me ~60% signal strength and 30% signal quality
Is it worth getting a satellite aligner gadget and compass and fiddle with the dish?
If it's not lined up 100% it would be a shame to try anything major?
you never know?I guess you could have a look to see if any of the screws / bolts that enable fine adjustment are lose at all.If they are all tight, then I doubt the dish has moved.
Where is it located? Is it possible it could have be mis-aligned by a football having hit it or something?
Or could a window cleaner have knocked it?
A rebuild shouldn't delete your recordings (didn't on my HD box). But it will get rid of any failed recordings.dont want to do the re-build until there is stuff left that i dont mind loosing.... but thats probably never gonna happen!
Are you sure?I have defragged which doesn't loose recordings. A re-build wipes the hard drive
whatever I did didn't wipe it!Are you sure?I have done a rebuild on my skyHD box and it didn't wipe my recordings.
It only takes a few mins so it's not like a "format C" type comand.
A complete system reset wipes the drive I believe.
I remember as a kid, we got the original BSB system. One day, a painter / decorate type chap was paining the outside of the house. He must have knocked the dish (denied it, of course) because we lost all channels (only got about five on that system).you never know?How exact is the alignment? a few degrees?
Fair comment and I don't blame you. (You've got me doubting what I did now!! )i was told by sky engineer last time he was here that a rebuild would wipe everything, so i dont want to risk anything that may wipe everything yet
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=270290038129Don't know how expensive those alignment meters are.
Can you get to borrow one or something?
There will be a degree of tolerance in there. Therefore, not every install has the same signal stength / signal quality values.its pointed at a satellite thousands of miles away... of course if its not aligned it aint gonna work very well!
I'll try that first!i have one of those. last time i tried to re-align dish it was easier with someone watching the signal level on TV
