user 38075
- Joined
- Aug 27, 2024
- Messages
- 8
- Reaction score
- 1
No particular need, it goes straight into the building from a floodlight.Is it SY cable?
The floodlight came with this gland. It doesn't ship with a cable.I asked if the cable the gland is used with is SY, trying to ID the gland type.
Why can't you use a normal stuffing gland?The floodlight came with this gland.
Its a specialised product, I'd prefer to use the part that came with it incase of any future issues.Why can't you use a normal stuffing gland?
God above, its a massive ships floodlight, its a specialised product, what does it matter?Oh. Several times you have said it is a "specialised product" but then you also said
So it's a flood light? why not post a picture of it, or details of supplier? Can't help you unless you are specific, which a picture or information would help no end.
Why would you assume I have no patience? this post is several days old.I would say the dome part goes in first then the other silver part to clamp the cable braid or armour, then the rubber, brass washer and bush.
I would suggest trial and error but judging from your last post you don't have much patience.
Gee why did I not think of that? perhaps its because I only have the one. Who would have guessed.Why don't you take the gland on another specialised product apart to get your answer rather than venting your spleen on here
The original post shows the gland in very clear sections and asks if anyone knows how it goes together, the only reply should be if someone knows, the rest is unnecessary in my view, that's why I am frustrated.
Everyone is only trying to help you, there is no need to be sarcastic, you clearly do not understand how forums work. If you persist with your outrage you will leave me little choice.
No, they are not helping, they are either stating the bleeding obvious or asking unrelated questions like your good self.Everyone is only trying to help you, there is no need to be sarcastic, you clearly do not understand how forums work. If you persist with your outrage you will leave me little choice.
