No Portable night storage heaters?
That video may not help much as there are many designs of over heat trip and some are not at all obvious where you push to reset it, and at least one you need to take it out to even gat at the reset bit. Oh and some have thermal fuses.
also be aware many contain asbestos linings. not much risk removing outer cover, but definitely is if you remove inner cover to change elements
Should that not be a requirement for LL to replace with an asbestos free storage heater then? How would one know if there is asbestos in there?
