Mr Fuxit
On a vehicle trailer, which is supplied with 230v AC, to the Earth of which the chassis and all metalwork is bonded, a 12V transformer/rectifier is tapped off to feed a 12V DC unit, the Neg/0V return of which is through the chassis. This has worked for years; it has never been a problem, and no-one has suggested it is a problem. However, I can find nothing in the Regs that helps. Perhaps i should add, that the 230V AC supply is to the latest specification and is compliant in every way.
Is there any reason this should not be used?
